So i created this loft in the sculpt context, from top to bottom and i ended up with the normals reversed. I went to the patch context and i couldn't select the body in order to reverse the normals.
The only solution i found was to unstitch the body, reverse normals, and stitch it back. Is this ok? It doesn't make sense to unstitch in order to reverse the normals.
