reverse curve/edge direction
jean-michel_legoff
Message 1 of 1
jean-michel_legoff
When inserting a point on path with th option "Physical" you enter a distance from the origin of the path. What about if you need the distance from the other end?
Could it be possible to "invert" the curve direction ?
in the same idea could it be possible to sketch a curve and define a "curve length"
Many Thanks
Replies (0)
