Replicate Jet Air Intake
chrisonemail
chrisonemail
I’m looking for advice on how to model an air intake duct in Fusion 360 for a model EDF jet. I’m focused on the area in the images only.
The intake transitions from a wide, shallow opening on the fuselage into a smaller circular duct feeding a centrally mounted fan. It’s the first 10 cm I’m trying to model. The shape curves in 3D, so it’s not just a straight or simple lofted transition.
What I’m trying to achieve is:
  • A smooth internal airflow path (no sharp transitions)
  • A clean transition from non-circular to circular geometry
  • Consistent wall thickness suitable for 3D printing
  • A method that gives good control over the final shape
I’d appreciate guidance on the best approach:
  • Is this best done with lofts, or surface modelling first?
  • How do you maintain control and avoid distortion in this kind of transition?
  • Would the Form (T-spline) workspace be more suitable?
Any recommended workflows or examples would be very helpful.
Thanks.
TheCADWhisperer
@chrisonemail
Can you File>Export your *.f3d file of your attempt to your local drive and then Attach it here to a Reply?
davebYYPCU
Will be Loft of some sort.
Most likely a sold Loft, with Rail for smooth control.
Even wall thickness comes from Modify > Shell. (removing front and back faces)
In your case you have a front slanted rectangle, (Lofting) inboard to a semi-circle.
Depending on your design, a simple centre line rail can do it.
that said, it has to fit into what already exists - and that was not presented.
Might help...
chrisonemail
Thanks. That makes sense. I’ll just need to get the rails to replicate the form.
chrisonemail
I’ll have another shot at it and attach what I’ve done. Thanks.
rosie_lucas1
Hi @chrisonemail,
I just wanted to check in and see if you’re still looking for help, or if you were able to resolve the issue with the feedback from @davebYYPCU.
If you need any further assistance, please feel free to share an update here. If you’ve already found a solution, we’d really appreciate it if you could share it with the community so others with similar questions can benefit as well.
Best regards,
Rosie | Community Manager
chrisonemail
Thanks for checking in. The feedback so far has been really helpful. I needed to replicate the exact dimensions of the intake and took a slightly different approach. I’ll now need to do some 3D prints to confirm the approach. It’s still a WIP.
