replace face on a solid
Hi, I want to replace this face of a solid with one that is slightly domed shape.  Can some one help me with this
Best regards
Ramstar
innovatenate
Autodesk Support
Autodesk Support
Hey Ramstar,
Welcome to the Fusion360 Community!
You may try using the Replace Face command highlighted in the below help topic.
http://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/CloudHelp/cloudhelp/ENU/Fusion-F...
Another option may be to use the Edit Face command. It's only avialable in the Direct Modeling environment (Create Base Feature). Check out the below screencast for more detail.
http://autode.sk/1yTPJ9E
I hope that helps! Let us know if you have any questions.
Nathan Chandler
Principal Specialist
