Rendering issues
Rendering issues
peterjonesGLA4K
Rendering issues
peterjonesGLA4K
I have an issue with rendering and there being missing items. I have seen a similar problem on another forum where people advise restarting Fusion and/or changing the appearance/material. I've tried these. I've checked if I need to clear the cache, that I have the latest version..everything.
The attached image shows a wheelhouse with a sequence of windows. There are blinds at 3 windows counting from the left. These are seen in the screen in the centre of the shot. You can see previous attempts at rendering along the scroll at the bottom, where only the left most window has blind material. I've tried the in-canvas option and as soon as I click that, the fabric part of the blind instantly disappear. I should also add that the blinds are a sub-assembly and strangely the cassette of the window blind and bottom rail do not disappear. It's just the blind material itself. If anyone has had the same experience and found a way to solve it, it would be much appreciated to learn about the solution.
johnsonshiue
Hi Peter,
Without seeing the actual file, it is hard to comment further. I would export the model to STEP and then import it back Fusion to compare the difference. If the missing components remain missing, either the missing part bodies may have quality issues or the parts are corrupted somehow. If the missing components reappear on the imported model, it may mean there could be graphics issues with the original model. Please feel free to share the files here. The forum experts can help take a look.
Many thanks!
Software Test Engineer
