rendering in white softbox
WawrzyniecW
WawrzyniecW
I want to render my product in white soft box to get clear white background around it. The best listing effect I got with Photo Booth environment but the background is grey. How can I create or where can I find ready environment with white background? I would like also to do some 360 deg turntable video with this product. Is it possible?
Rafal.Chlod
Autodesk Support
Autodesk Support
Hi @WawrzyniecW, thanks for posting.
You can adjust your render background by using Scene Settings option. Select Solid Color, click the color under the drop-down list and customize the background color to your liking.
To make animations, choose Animation section in Fusion 360. If you need some instructions, check this tutorial.
If my answer helped you, please click Accept Solution. Thanks!
Rafał Chłód
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
