Rendering gallery error...
I have a problem to reach my renders that I've rendered using the cloud function. When I click the small thumbnail of the render I get the following message: "Your rendering could not be loaded because an error occurred.". It has worked before and I really need to get it to work as soon as possible for a school assignment.... 😕
Thank you for any help!
Niklas
I experience the same problem! Is this something with your servers?
TrippyLighting
You might be able to access these renders through your personal A360 hub as described in this thread.
Hi , I actually have the same issue.
I tried through the web access.
The problem is I can have access to ONE render (the last one) which has been launched. The 12 (!) other ones are just nowhere... 😕
It's OK, i'll explain to my CEO that i cannot render for some reason...
Disapointing.
jwiersma
Yep, same problem here...Can't access the completed rendered image from Fusion.
Still enjoying the wonders of Fusion 360 though Smiley Happy
I trust in the team to work it out!
Greets
brianrepp
All - thank you for the heads-up on this.  We have confirmed this is indeed an issue and are working to get things up and running as quickly as possible.
