Render: no shadow on white background?
Nickduino
Message 1 of 16
Nickduino
I designed a simple switch and I'd like to make a render of it. Ideally, I'd want the background to be transparent but that's impossible with Fusion 360, so the next best thing is white. Alas, it doesn't work:
If I change the background to a light gray (only modification):
What's up with that?
EDIT : The object: https://a360.co/2G63AFB
Replies (15)
Message 2 of 16
jodom4
Hey Nickduino,
When you click on a rendered image in the Render Gallery, then click the Download  Image icon, there's a toggle for transparent background. You can then download either a TIFF or a PNG with an alpha channel.
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
Message 3 of 16
Nickduino
Yes but it hides the shadows as well, that's why I said it was no bueno
Message 4 of 16
JamieGilchrist
did  you try turning off the ground plane in the settings dialog?
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
Message 5 of 16
Nickduino
If I turning off the ground plane, there is no plane on which the shadow can be casted!
(And yes I tried nonetheless)
I want:
  • a white (or transparent) background
  • a shadow
Is it possible that Fusion 360 can't do it?
Message 6 of 16
I also want to do this and cannot find a way to do it!
Message 7 of 16
Nickduino
What's more frustrating than a feature not being there is not really knowing and Autodesk won't answer this thread since already three people did...
Message 8 of 16
davide.finizia
Observer
Observer
Same problem here!
I also want to do this and there is no way to do it!
It is unbelievable that Autodesk team has not yet solved this problem, we need darker shadows using solid white background. Is it so difficult to manage this request?
Message 9 of 16
ametedinov
Same problem here. It's been years since people started making this request on various forums and no response from Autodesk
Message 10 of 16
coleUFHX5
Any fix to this?
Message 11 of 16
Nickduino
It doesn't seem so
Message 12 of 16
TrippyLighting
What "fix" are you looking for. I don't see anything broken!
Message 13 of 16
e11828334
Broken is: Shadows are there when rendered with gray background, but shadows are not there when rendered eith white or transparent background.
Could someone please fix this?
Message 14 of 16
TrippyLighting
@e11828334 before I asked what needs to be fixed, I tried this out on the model that was posted in this thread. Getting a shadow on a white background worked fine after some experimentation.
Perhaps if you can post your model, I can look into it and see what can be done.
Message 15 of 16
e11828334
I can't upload the project because of personal reasons.  What did you do with the project of the original poster in order to get the shading right? You said you played around a little, can you further explain?
Message 16 of 16
TrippyLighting
I don't exactly remember, but usually using an HDRI with a smaller  light source and less diffuse environment helps creating sharper shadows..
Increasing the roughness of the material of the surface that receives the shadow and sometimes decreasing reflectivity also are viable means.
