Render moving parts?
OK 2 files here. Capture image is exactly that.  When I go to do a local render, it shows some parts as moved.  What's the dealio with that?  I can't really send that render to a customer when it's supposed to look like the captured image!
lucasliraAU
Hello
This really seems to be a nuisance to your presentation.
you could share your file so I can perform some testing.
Best regards!
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
lucasliraAU
Hello again!
I'm analyzing your work ...
I'm also facing the same problem when I run the 360 rendering in the cloud.
As this work should be presented to your client the best alternative to solve this problem in a short time is running a local rendering I have been running these.
I hope this can help you in your work until now, I will be enventigando more on this case in search of new solutions ...
Kind regards.
Renders attached.
It was doing it to me when I rendered it locally as well. I didn't use the cloud to render.
lucasliraAU
Here I have no problem in place, when run in the cloud the parts remain mobile.
lucasliraAU
I hope these pictures can help with your work!
Yes.  Thank you.
