Removing Material
Removing Material
daniel.rindt
Removing Material
daniel.rindt
i try to remove material which previously created by a loft. The cut should exactly remove the room between the 2 faces you can see in the attachment. I could use the extrusion with "cut" option selected but how to calculate the tamper angle then? If that is the way i should go.
Thank you a lot,
Daniel
davebYYPCU
I would use the Modify > Shell command. and clicking on top and bottom faces, will remove those faces,
But if you want to keep the faces, select the body in the browser
daniel.rindt
I need the room between both profiles, the reason is that it's not a square, its conical.
TrippyLighting
Have you tired the shell command as suggested ?
i am not sure i understand your last post. If you only need the upper, or lower part hollowed, then you can make a second loft and use Modify-> combine-cut
davebYYPCU
This any better? Loft with cut.
