Removing Lines
Removing Lines
Removing Lines
I am fairly new with Fusion 360 (Just started today and have come across a problem i cant seem to fix) I have a 3D object with lines in i that I do not want. Any Help?
etfrench
Most likely reason is the surfaces are not at the same level.  Try using the Extrude command and set the Extent parameter to the "To Object" option.
p.s. The yellow highlights in the Timeline mean those items have errors.  You should correct those before moving on.
ETFrench
