Remove Joint feature - feature requst
If Joints are a feature in the Timeline (which I would argue doesn't make sense), then should there be a Remove Joint feature similar to the Remove Bodies feature?
Case in point - I have components that are still being developed, I join Component A with Component B, I build out some new features on Component A, which reference Component B. This instigates a position change on Component B, but if I delete the joint, I lose the reference which defined the features. This is basically the same use case as multiple bodies.
Alternatively, joints just shouldn't be in the timeline. If I redefine features to which a joint is mated, it should recognize if those features have changed, and prompt me to reassociate the joint features.
