Remodelling existing objects.
SimonPlatten
Message 1 of 20
SimonPlatten
In the attached image the selected area represents the blade I would like to curve,  presently its a straight up and I would like to curve every blade in the image so it captures the are flow better, is there a way to do this without going back to sketch?
Replies (19)
Message 2 of 20
g-andresen
If it is a sketch based feature you need to edit the sketch.
But it is then about a single element because of the pattern.
günther
Message 3 of 20
SimonPlatten
How can the sketch achieve that?  The sketch is a 2d image where it represents the curves around the circle which are extruded up?  I want to curve the part that is extruded.
Message 4 of 20
TheCADWhisperer
@SimonPlatten wrote:
I would like to curve every blade in the image so it captures the air flow better....
Image editing is done in software like Photoshop.
For 3D CAD editing - Attach your file(s) here.
Message 5 of 20
SimonPlatten
I don't want to edit the image, I want to edit the model.
Message 6 of 20
mango.freund
hello @SimonPlatten  --- take a look its only with move/copy command. but give your work in a file and we will see.
draft is also possible for modify see left two plates
Message 7 of 20
g-andresen
please give some more information of what you want to be changed.
> handsketch ...
günther
Message 8 of 20
SimonPlatten
@g-andresen , the blades are currently extruded up from the base and curved from the original sketch, I want to implement another curved instead of a vertical extrusion, I want to replace its a curve to add the blades in capturing the air flow.
Message 9 of 20
davebYYPCU
Keep profile sketch, create Path Sketch,
Sweep the original profile, on a curved Path,
cancel Extrude and edit pattern for the new Sweep.
Might help...
Message 10 of 20
SimonPlatten
@davebYYPCU , I'm having problems now since its quite a large project locating the original sketch.
Message 11 of 20
davebYYPCU
Name your sketches?
Roll timeline to beginning, step, step >>>>>
until it comes to light.
Do your editing, and fix broken icons as you keep stepping to the right.
Might help....
Message 12 of 20
g-andresen
Why don't you post pictures?
Is that what you want to achieve?
günther
Message 13 of 20
SimonPlatten
@g-andresen , yes thats exactly what I want to achieve.
Message 14 of 20
SimonPlatten
How do I replicate that?
Message 15 of 20
g-andresen
go step by step through the timeline and study* the individual planes, sketches and features
günther
* rightclick > Edit
Message 16 of 20
SimonPlatten
Thank you, I see now!
Message 17 of 20
SimonPlatten
Probably another newbie question, I've selected the top of the object and clicked create sketch, I can set the outline of the object I clicked on when I created the sketch, but it isn't in the sketch itself, if I drag select the outline is visible but its still not in the sketch, is there anyway to make the selected outline part of the sketch?
Message 18 of 20
davebYYPCU
This is tricky to explain - reading between the lines, but you will work it out.
you want to edit a vertical blade to something similar to Gunther’s wheel.
you created a sketch, on the top of your extruded blade.  Depending on preferences, and
hide the extruded blade, I presume you can see the profile (blue shading from the top of the blade.)
if correct, so far,
your profile shading is actually in your sketch, - because it was projected you can’t move it, until you window select your sketch items and break the link.  Now you should be able to move the sketch items, but to be honest, I have never tried to move a projected broken link profile.
If not - will need the file.
Message 19 of 20
g-andresen
try this
günther
Message 20 of 20
SimonPlatten
Thank you, will take a look
