ReMake mesh is not quad
SaeedHamza
Advisor Advisor
SaeedHamza
when i insert my mesh from ReMake it doesn't come in quad but triangles so it can't be converted into a T-Spline body
so is there are bodies that can't be a quad
thank you
Saeed Hamza
PhilProcarioJr
@SaeedHamza
Is your mesh a quad mesh before bringing it into Fusion and when you go into your Fusion properties and look under the mesh setting do you have the triangulation turned off?
Phil Procario Jr.
Owner, Laser & CNC Creations
jeff_strater
There is an option to control this.
If you turn on the "Mesh Preview" in your preferences:
Then, you would need to to turn off the "triangulate" option:
Jeff
Jeff Strater
Engineering Director
SaeedHamza
solved!
thank u so much guys 🙂
Saeed Hamza
khokeson
I just spent like 4+ hours running through different programs retopologizing and banging my head against the wall trying to figure out why when exporting as Quads Fusion was still seeing Tris. Dumb me thought it had to be some setting with how I was exporting it.
I can't thank you enough. I would hug the heck out of you if I could. Thank you!
