Relocating components, paste new problem
Message 1 of 21
I can't for the life of me what's going on here.  So I have two components, component B being defined onto a face of component A.  If I then copy and paste new these two components, everything is fine.
However if I first put these two components as subcomponents into a new empty component C, then try copy and paste new this component C, I get a reference failure.  Specifically, it's as if the face reference that component B was defined on is lost by simply restructuring A and B as subcomponents, such that they can no longer be copy-pasted new.  This same problem also arises if sketches are used.
Here's a short screencast to illustrate:
https://knowledge.autodesk.com/community/screencast/ec356c43-4bfe-4f42-91e7-8c86c4f6803a
I found a work around is to insert the model into a new model as many times as needed and then break link for each, but was curious if I'm missing something again?
Thanks again,
Jesse
Replies (20)
Message 21 of 21
TheCADWhisperer
@g1_e2_o3_r4_g5_e6123456
I am curious about what that was.
I can tell you if this were my design I would not have any Positions and likely no user created workplanes.
I can tell you that this would be my first Component modeled symmetrically about the Origin
and
Grounded.
Edit: And all of my sketches would be fully defined.
