I am working on a model that contains several components. After I finished my model, I created a new version where I changed a few things. One change is that I moved 2 components 1 mm downwards (PCB and a upside down pushbutton).
As a result of this action, the bottom of the pushbutton, is colliding with the Housing (penetrates it for 1mm).
In my sketch to draw the bottom of the Housing, I referenced the bottom of the pushbutton. I projected the bottom of the pushbutton and used some colinear constraints as marked in below screenshot.
But now the pushbutton is 1 mm lower, but it looks like the bottom part of the Holder isn't correctly updated. No problem, I will just redo it. But the projection of the pushbutton still seems to use the previous position (1 mm higher). I can't even redo the projection, because the button is still at the original position when I edit the sketch. It means that the position of the pushbutton in the sketch is different as the real position in the model - it is as it "remembers" the original position, and doesn't show the new position. So I can't undo/redo the projection.
Question: Is there a way to kind of "update" the position of the pushbutton in the sketch, so that I can redo the projection, and re-reference bottom of it?
Attached you find the model.
