Redefine sketch plane
This function does not show up on my system?
George-Roberts
Can you take a screenshot of what is shown when you right click a sketch from the tree?
There you go, thanks.
TrippyLighting
I believe that function is not available in direct modeling mode.
I had a feeling that was the case but when I tried it I had already started the design in direct mode and then switched to capture design history, so that’s probably why it did not work.
Out of interest is there a document that you know about that lists the functionality you lose when in direct mode?
Thanks for your help.
TrippyLighting
No, not really. I work mostly with the timeline enabled.
