05:59 PM
Hi everyone
I'm trying to create a compliant mechanism to 3D print similar to here. I'm having issues trying to create a rectangular/linear pattern with a cut extrusion, to create the feature that allows the part to flex. In the first photo you can see that where the arrow is pointing is closed, which means I can select that as a feature rather than a face. However, in the second photo the face isn't closed and selects that entire face rather than the small rectangle in the first. The third photo shows what I selected to make the cut.
Closed Face
Open Face
What I extruded/cut
