Recreate view from previous render
Hi Guys,
I've completed a number of renders of a product in different colors, but have found that I need to recreate one of the render but I used a custom view and was wondering if there was a method of re-positioning the item item to the view used in the render.
The render file name seems to have stored coordinates for the view "CustomizedView388725081" in the file name. How can I manually set this view?
Best,
Kevin
lichtzeichenanlage
AFAIK this is not possible. What you can do is to create custom views and you can use those in e.g. renderings or drawings.
laughingcreek
If you drag the render over to the box labeled "render on save"  you get a fresh render with all of the original settings and with the same view.  just make sure yo drag it back so you don't get a new render every time you save.
It won't be the original resolution settings, at least not in my experience. it is very low resolution and then you can't re-render locally, but they do allow you to pay to render at the original resolution.
