Raspberry with shield
Hello
I designed a shield for my raspberry with more electronics components, basically it's twice the height of the raspberry itself. I'm totally new to Fusion 360 and I would like to build a case for this, knowing the height is not standard. I tried to update this model found on Autodesk Gallery, but I can't find how to do it. Is it at least possible or should I start from scratch ?
https://gallery.autodesk.com/fusion360/projects/raspberry-pi-3-2-or-bplus-case
Any idea ?
Mickael.
innovatenate
Autodesk Support
Autodesk Support
Welcome to the Fusion 360 Community!
Does the solution in the below link help? You should be able to upload the F3D file from the gallery.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
I hope that helps!
Let me know if you have any other questions.
Nathan Chandler
Principal Specialist
etfrench
It depends on whether the Rasberry is attached to the upper or lower part.  This screencast assumes it's attached to the lower part.  You'll need to move the split part the correct distance for your shield and possible change the height for the posts.
ETFrench
Waoh many thanks, this video cast has been so helpful ! Thanks for taking the time to help me !
