Rapid Movement to Linear Movements
I am fairly new to Fusion 360. I am trying my best to learn how to change a rapid movement into a linear movement in CAM (or any other movement other than rapid). Obviously this is in relation to the recent changes to the personal use version. I am totally cool with longer machining times on my CNC but right now I can't figure out how to not use rapid movements. Any help would be greatly appreciated.
etfrench
Fusion 360 has already taken care of that for you.  The G0 (rapids) have been replaced with G1 (linear) codes.  If you still have G0 codes in your gcode then be thankful 😀
ETFrench
PG.Eng2
rapid movements are defined in your machine.
Options:
- Lower or use rapid feedrate override on your machine
- Open gcode file in editor and change all G0 to G1 and at end of G1 line add Fxxx with your desired feedrate at xxx
- Change your postprocessor to write G0+Fxxx instead of G1
etfrench
Options:
That won't work in LinuxCNC.  G0 speed is set in the ini file.  Besides that, there is no reason to change G0 to G1.
ETFrench
So you are saying I can do one of those three options? Or I have to do all three of them?
etfrench
Well, I'll make it easy for you.  You don't have to do anything.  If Fusion 360 is putting G0 commands in your gcode, say Thank You.  There is absolutely no reason to convert a G0 command to G1.
ETFrench
PG.Eng2
I think your machine and cam is working as expected. If you program a rapid move, it will move at rapid speeds. However it seems you prefer to not move at this fast speed.
Normally you don't program a feedrate for rapid moves in CAM software. This is because the rapid feedrate is defined in your machine / controller.
I think in another post you mentioned you use GRBL as the controller for your machine.
In GRBL you can define the maximum speed at which your machine moves in variables $100, $111 and $112 for your X, Y and Z axes respectively. If you lower the number at these variables to whatever maximum speed you feel comfortable with the machine will not move faster than those programmed speeds.
An alternative workaround if you do not want to change your GRBL configuration file is also possible, but i have to say these are workarounds and not common practice.
For example you can change your G-Code file:
Explanation of how gcode works:
Rapid move is initiated by G0 command:
G0 X10 Y10 will move your machine to X10 Y10 at rapid speed. (the maximum speed defined in GRBL $110, $111, $112 for example)
Feed rate move is initiated by G1 command:
G1 X10 Y10 F100 will move your machine to X10 Y 10 at a feedrate of 100/min.
So if you have a gcode file and change all the G0 moves to G1 moves, and add the feedrate you want to move at at the end the machine will not move at rapid rate during running of the program. You can do this manually in your G-Code file or use a text editor like Notepad++ with regex to do this quickly for a complete file. (see example find and replace using regex)
