Radius Bug and more
I have created a very simple three point ark with a 94mm radius and extruded it to 102mm in length. I then wish to fillet the edge to create this simple pill shape. I am able to select one upper edge and radius it to exactly 94mm and get a wonderful circular end cap. However is I select both edges I gat a fail and am only able to radius to 93mm before the operation fails. It does not matter what end I choose (second image), I can only radius one of them to the correct perfect radius. I have done this sucessfulky in the past, not sure why this is not working. Also, now when I go to take a screen shot of the this issue and press control option 4 the radius gets undone and I can take screen shot to show you, so you have an OSX hot key issue as well (first image)
Good luck.
