Radius and copy
Radius and copy
Radius and copy
I have drawn a shaft with a keyway at one end. I now need to put a radius in the end of the keyway and then I need to copy the result to put in the same keyway in other locations. Any help would be most appreciated.
Brian
davebYYPCU
I presume you cut the key way with an Extrude along the shaft, resulting with square end plate.  Fillet the two edges with half slot width.
you could also sketch a slot on the top view, with overhang and extrude to suitable depth.
would need more information about use for other models.
Might help....
Many thanks Dave, I'll get the hang of Fusion 360 eventually.
Brian
