R Patern Warning on hole patern when changing parameter
administratieWFZXC
administratieWFZXC
Hi!
I'm trying to use parameters to make a hole grid on a board, however when I edit my LengthWidth Parameter I get the following error:
R-Pattern1
Compute Warning
The expression specifying the pattern count does not evaluate to an exact integer value. Edit the expression to repair it.
Any thought on solving this error? The design updates as intended (Extra holes get added when I enlarge the board, Holes get removed when I shrink the board)
See attached file and a snapshot for reference
Any help is greatly appreciated 🙂
kacper.suchomski
Hi
You've done a lot of hard work to make Fusion's calculations more difficult.
(view in My Videos)
Of course, your equations do not allow for rounding or conditions, so you must remember that the dimensions must be multiples of the array element's pitch value.
Kacper Suchomski
administratieWFZXC
Thank you @kacper.suchomski for your help! Yes, I'm good at making things more difficult 🙂
I thought I needed to divide by 1mm to use the distance values as a quantity value, but now I see that's not necessary. lots to learn!
