"Vertices" not connected when creating fillet
ttotsbarc479HK
Message 1 of 8
ttotsbarc479HK
I just started learning how to use this software this weekend...
I am trying to create a fillet along this edge but when I do the "vertices" separate at the point where they are connected. Any idea why this is?
Replies (7)
Message 2 of 8
laughingcreek
try using cord length-
Message 3 of 8
ttotsbarc479HK
Thanks for your advice...
That helped alleviate the issue quite a bit, but there are still points that are disconnected.
To create this large body/piece I had used a "Loft", perhaps that somehow cause the points to not merge for some reason..?
Message 4 of 8
g-andresen
Please share the file for reply.
File > export > save as f3d on local drive  > attach to post.
günther
Message 5 of 8
ttotsbarc479HK
Hey there,
Attached here is the exported file.
I attached two files:
-First is without the fillet, so you can see it before the fillet was used.
-Second is with the fillet.
One thought I had is that my object is very small...could that be causing the issue?
Also, as a side note...I might be approaching this form the wrong way, maybe there is an easier way to create that piece without using a "loft" on that top gentle arch.  Since I'm new to the tool, I a loft seemed like the best approach. 🙂
Thanks for taking a look.
Message 6 of 8
TheCADWhisperer
I recommend that you start over and enable Capture Design History.
Message 7 of 8
davebYYPCU
Plain and simple geometry.
Measure the angles at each pair of faces.
The same fillet size dictates that the tangent connections must separate.
Might help…
Message 8 of 8
ttotsbarc479HK
Thanks all for your suggestions...Ill try starting over and using some of that advice plus some other stuff I have found online,
Ill report back if things work out 🙂
