"Stopped Chafer" solution help appreciated
marks3U6W9
marks3U6W9
I m looking for a quick way to put a stopped chamfer (common in woodworking) on a number of edges in a model of a door. I have seen some solutions proposed in the past but they all look quite time consuming and I just wondered whether anyone had an ideas of a quick way to do this. Many thanks
SaeedHamza
Attach something like a .f3d file or anything that helps us understand you're case
Regards
Saeed Hamza
etfrench
Here's one way to make stopped chamfers:
It would probably be better to use a fillet with the radius of your cutter on the ends instead of the chamfer operation.  You should also use an exact measurement when creating the chamfer/fillet instead of eyeballing (technical CAD term Smiley Happy ) it.  Also use User parameters to control the distances of the main chamfers.  It will be much easier to modify the design later.
ETFrench
laughingcreek
2 additional ways would be to use a sweep workflow, or a "split body" workflow.  (both will work on curved edges)
Here's an example using split body-
marks3U6W9
Very nicely done. Many thanks
