"Move" has a glitch
"Move" has a glitch
"Move" has a glitch
When I insert a new model into a design and use the move tool. I can use the "Free Move" to rotate my part into orientation, but I am forced to close out of "Move" and re open it if I want to use Point to Point.
Otherwise when I use the drop down right after Free Move to POint to Point it reverts my part position where it was when I started.
daniel_lyall
@Anonymous If you do the free move don't hit ok right click push up relise the right mouse button, it start's the move tool again then select point to point and do your move, it stops it going back to it's old potion.
They are going to fix this so you don't have to do the repeat command.
Right click mouse button push up and relise the right mouse button is the repeat command, same as right click to bring the menu up and select the top command what is the last command used
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
