09:55 AM
I have come across this problem numerous times. I solved it by dimensioning one side, and then setting the other dimension to equal the first by clicking the first. This only works if you're directly defining the dimension — in many cases, I want dimension B to be equal to dimension A, but dimension A is defined by other entities in the sketch, such as projected model geometry.
I am a Solidworks convert. This would not be over-constrained in Solidworks. I am trying to make the hole in the A and the O equal width. I can drag them horizontally, but I can't set them "equal". Any idea how I can set them that way?
Thanks!
