"Auth Token Can not be null" error
Message 1 of 8
heya, I'm trying to follow the Fusion 360 Mastery course. In lesson 6 however once i use the "view details on the web" option the browser displays a "Auth Token Can not be null." error and only loades the myhub enviroment and not the actuall model...
Replies (7)
Message 2 of 8
wouter.devriese
Hi
same error over here, uploaded designs are not being imported due to this (I guess).
Did you get any feedback/help?
Message 3 of 8
no, I didn't. But it worked the next day, so .....
good luck!
Message 4 of 8
wycFLRTE
Observer
Observer
Has this been solved?
I have been having a problem with "Auth Token Can not be null." for a week now..
  • I cannot view files online. Project folders appear empty and the "Auth Token Can not be null." flashes at the top of the screen every time I:
    • Open a project folder
    • Attempt to open one of the items in the activity pane
  • Some files do not get new versions. They remain V1 despite being changed and saved
  • I have an upload queue that never ends, yet my files are visible in
    • the iOS app
    • the activity pane
    • Autodesk desktop connector
    • Trash of each project (deleted files)
    • Shared links to a file
@karina.harper, you have been solving similar problems. Any thoughts on this one?
Message 5 of 8
karina.harper
Autodesk Support
Autodesk Support
Hi @wycFLRTE
Can you try the following for me? If that doesn't work, then we may need to log a ticket with our back end team. Let me know how this goes:
  1. Open Fusion Team in an incognito browser.
  2. Log out and back in.
  3. Open Fusion Team in a standard browser.
If the solution is not working try to below steps:
  1. Sign in to your Autodesk Account at manage.autodesk.com and click User Management > By User
  2. Remove the product from the User, and re-assign.
  3. Close the browser and open the Fusion Team.
Cheers!
Karina
Message 6 of 8
@karina.harper I have the same issue and this solution solves it, but only for limited time. After a couple of days I need to do it again. Can you please tell me where I can issue a ticket or how to overcome this? It's became really annoying as I need to do it every time I want to access the project files preview.
Message 7 of 8
karina.harper
Autodesk Support
Autodesk Support
Hi @Anonymous
You can create a support case here, then we can create a ticket with development.
Cheers,
Karina
Message 8 of 8
Ok, thanks. It's registered as Case number 17379188
