Message 1 of 14
I am trying to create a pyramid shape in 10 stages using the loft command. I started out by created a sketch for each block with each block smaller than the other with the loft command, but when I do, it looks like a soft cone instead of a rigid pyramid shape.
Then I started over and created a sketch for each tier and made each tier with its own loft command, which ended up a success but there must be a better way.
The next step is to create a shell but I'm having an issue with it as it would only grab the bottom tier.
Any suggestions would be great!
