Push Pull Localised Area of Curved Surface
formsR28H6
formsR28H6
I'm quite new to F360 and wondered if it is possible to push - pull a localised part of a curved surface ?
A bit difficult to explain what I mean, but let's say I have an egg shell, and I want to define a round profile area around the top 5mm of the egg, and then pull the center of that profile it to make it sharper, or push it to make the inner / outer curvatures flatter.
Is that type of feature supported in Fusion 360 ??
I have read & adjusted my description a few times, it does not seem very well described, I hope that it's understandable ?
g-andresen
Please share the file and show what you want to achieve in the end. > handsketch or picture of real existing object
File > export > save as f3d on local drive  > attach it to the next post.
günther
davebYYPCU
If the egg is a T-Spline, then that is so easy to do with Edit form.
Might help....
formsR28H6
@davebYYPCU - thanks so much, but unfortunately it was imported from a .step file as a single body.
jeff_strater
the answer (though hard to tell without the model and a better idea of what you want to achieve) is really "no". You cannot make localized changes to one area of a BRep face (solid body). You may be able to get part of the way there in a Direct Model using "edit face".
Jeff Strater
Engineering Director
TheCADWhisperer
