.psm import
.psm import
bryan5
.psm import
bryan5
Fusion now has the ability to convert an imported model into sheet metal.
I would be nice to have the ability to import Solid Edge .psm files since this is the sheet metal extension for Solid Edge sheet metal models.
Thank you
Bryan Lagrange
dsouzasujay
Hi @bryan5 ,
Today Fusion 360 Supports does not support SolidEdge Sheet Metal (.PSM).
Workaround is to export from SolidEdge as Step, x_t\x_b, parasolids file and Import in Fusion 360.
For SolidEdge Part and Assembly files: Fusion Team Hub has AnyCAD feature that supports SolidEdge formats (.par & .asm): Demo For AnyCAD
Further, to support .psm on Fusion 360, please post this question on Idea Station
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
