Projection does not update
fischer612
Message 1 of 12
fischer612
There are 2 bodies in this "buckle" sketch, the "fork" and it's "housing".
I projected the fork in a sketch on the housing's top face, as can be seen in images 1 & 2.
When I update the buckle's dimensions (it's height from 30mm to 35mm, images 1 & 3) the projection does not update.
Why is that? Thanks.
Just to clarify - on image 2 the top body ("housing") appears while in image 4 it's hidden.
1.
2.
3.
4.
Replies (11)
Message 2 of 12
Steven_Gao
Can you attach the f3d file in here for further investigation?
Steven Gao
Fusion & Inventor Quality Assurance
https://www.autodesk.com/campaigns/fusion-360/insider-program
Message 3 of 12
fischer612
Here. Thanks
Message 4 of 12
aliobidi
Hi ,
I fix it .. some sketch line issue
but you need to fix the time line and check it .. your file below
Message 5 of 12
Steven_Gao
After I changed the 30->35 in Sketch 1, I saw several compute failure in sketch 9 and other sketches. Refer to attached picture. This may the reason for the offset objects are failed to update.
Steven Gao
Message 6 of 12
fischer612
Thank you. Could you explain please what was the problem and the solution?
Message 7 of 12
aliobidi
just don't link the offset sketch with sketch line Incorrectly or not important (in the same sketch )
this helps when you edit in the past of time line to going right into the present
Message 8 of 12
fischer612
Excuse me I could not understand what you meant. I don't understand what I did wrong?
Message 9 of 12
aliobidi
like these lines .. they constraint with the offset sketch
while you can make them into another sketch
And be Certain when you make something like offset tool the result line is chained > easier for editing
what I mean just Keep the file organized to avoid problems with Fusion 360 logic
finally you didn't doing wrong it is just some organizing issue
Message 10 of 12
fischer612
I think it's not relevant. The warning referrs to a coincindent constraint, I simply removed it and every other line realted and kept only the offset. Problem remains. I'm frustrated
Message 11 of 12
fischer612
Ok I deleted all these extra lines and finally it worked! Thank you very much man! That was frustrating.
But now how do I work with that? The project lines are useless alone...
Message 12 of 12
aliobidi
well ,with new sketch and project if needed
