projecting sketch bug
abecedarian
abecedarian
There is a picky bug related to sketch projections.  Here is the error I receive:
"Error: Projection of the selected spline/curve would result in a degenerate segment and cause future modeling problems!"
The spline sketch I am using to cut from a volume requires a small arbitrary point nudge to allow for a sketch to be projected from the resulting shape's surface.  I can email a file to a QA with steps to reproduce.
Here is a screengrab:
Thanks!
-Chris
innovatenate
Autodesk Support
Autodesk Support
Thanks for sharing Chris!
Could you share a public link of the design with me?
http://forums.autodesk.com/t5/design-differently/share-a-public-link-of-your-fusion-360-design/ba-p/...
Nathan Chandler
Principal Specialist
abecedarian
Hi Nathan, thanks for your help.  The steps shown below are more reliable than what I showed in my original post.
Here is a link to the file in question:
http://a360.co/1ScRrLW
Steps to reproduce (1-12):
1) open file and choose >Sketch >Project/Include >Project
2) click on the ground plane to set the orientation of the projected sketch
3) click on the flat top surface of the "Gear" body
4) notice the error message
5) undo all steps or re-open the file
6) click on the top view of the ViewCube
7) delete the point shown in this image
8) click on the Home view next to the ViewCube
9) choose >Sketch >Project/Include >Project
10) click on the ground plane to set the orientation of the projected sketch
11) click on the flat top surface of the "Gear" body
12) notice the successfully projected sketch on the ground plane
innovatenate
Autodesk Support
Autodesk Support
Thanks  for posting this. The project tools seems to be warning of a "degenerate segment" that could lead to future issues. I'm not exactly sure what future issues. I've logged a report with development (ID: FUS-20906). My best guess is the projection tool is generating an approximation of the spline, but failing for some reason. I'll circle back once I learn more.
Thanks for sharing!
Nathan Chandler
abecedarian
Thank you, Nathan.  I look forward to hearing back.
-Chris
abecedarian
I think I have run into another possible bug involving projection sketches.  Any updates on this one?  Thanks!
