project to surface Circle sketch cannot be Patched after new update.
capt_mbm
capt_mbm
after the last update I am not able to patch a circle that is projected to surface. please check the video below after the update
capt_mbm
This is how it used to be before the update.
laughingcreek
that's a weird regression, and hopefully someone from AD will be along to record it as a bug.
I would suggest that instead of projecting to a surface, you instead split the surface.  the curvature quality is much better-
capt_mbm
that is a good Idea. I will try that. I hope they manage to solve this issue as i need it for most of my design. alternately I will try out your suggestion.
Phil.E
Logged as FUS-151036. Thanks!
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
