Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Project sketch, a lot of points
6 REPLIES 6
cristianmatabanchoy
177 Views, 6 Replies
Hi!
First of all I had to create an account because with my usual account, it gets buggy when I try to enter the forums.
So, does anyone know why when I do a projection, I get so many dots? It is only in the projection, when I make the drawing as the larger circle comes out normal.
The only different thing is that I copied this file from another file, and all the faces and bodies that I try to project I get dots.
Tags (2)
Labels (1)
6 REPLIES 6
Imported geometry - there are file conversion to Fusion compatible things going on.
Not checked the file.
Might help….
I have previewed all of your sketches and I do not see one containing the points you describe.  I also project the edge you circled into a new sketch and also did not see the points you describe.  Please attach your model and identify which sketch you are referring to.
John Hackney, Retired
Yes sorry I uploaded the wrong file, I just uploaded it again.
Hello!
So inside the Fusion360 panel I right clicked copy and in the same panel the project was copied, it was an internal copy.
Because the cylinder is not concentric with the sphere the edge is not a circle when you project the edge to a sketch perpendicular to the cylinder. If you try projecting the surface then you get the 2 surface edges so again not a simple circle.
What you actually get is a spline. If you zoom in you can see the control points.
The only thing you could do is create a plane through the middle of the cylinder then use project intersect to create a circle at the intersection then project to your sketch.
See attached file.
Mark Hughes
Owner, Hughes Tooling
Hi!
Yes sir that was the problem, I just projected as I was expecting.
Thank you!
