Project line to surface: How do you transform projected line as solid lines
Hi All,
Please see attached images.
The design isn't a body; it is currently a surface. I have to amend the surface by sectioning it before a can change it to a body. This is the reason I used the project to surface function.
I have 2 questions:
1. From Image 1, how do I convert the projected lines (in purple) into a solid line and also edit them so that I can extrude art of the surface?
2. From Image 1 & 2, the surface is broken into many pieces. how can I make it into 1 piece? In the second Image, I have just changed the visual style to "shaded" only but it does not change the surface parts.
Santhosh Suresh
g-andresen
1. this way:
Attention: then there is no link to the original object anymore.
2.  create a new thread > share the design to take a look at
günther
Skinz!
Observer
Observer
thank you!!! ive been wondering about this as well.
