03:15 PM
I'm trying to build intersecting, orthogonal splines to use in making a lofted surface. It has been suggested that I use the Sketch/Project/Intersect command to create points on one set of splines, then connect the ends of the perpendiculars by making them coincident with the points, which makes a lot of sense. However, there is no longer a pull down menu for sketches, and only a "Project" command, with no "intersect" choice. Has this been eliminated in the newer versions of Fusion, or am I not set up correctly, or ????
Would greatly appreciate any assistance.
