Project Intersect BUG
HughesTooling
Consultant Consultant
HughesTooling
I found a bug with project intersect, if you modify the model so an edge disappears there's no way to fix the error. You can delete the yellow point that indicate a problem but you can't clear the error, see screencast. File's attached.
Mark
Mark Hughes
Owner, Hughes Tooling
paul.clauss
Hi @HughesTooling
Thank you for bringing this to our attention! I was able to recreate the bug in your file, and have logged an issue with development (FUS-28935). I will circle back here with an update when I hear back from them.
Kind Regards,
Paul Clauss
Product Support Specialist
