Project from other planes.
tijuanakez
tijuanakez
I have a part for which I want to cover the interior surface with some thin foam, which I'd like to laser cut out.
You can see from this shape, it would be 2 L shaped pieces for top and bottom and 2 rectangles for the back and side pieces.
How would one go about projecting all these shapes down onto a seperate flat plane so I can send this to the laser software?
davebYYPCU
Few ways to do it, but laying flat will be done externally?
I would model the foam pieces,
extract the faces into dxf.
Might help....
TheCADWhisperer
What is the foam thickness?
