Project became extremly laggy and I get this error when attempting to cut the file: Error: There was a problem combining geometry together.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I was trying to design a project based on a gameboy shell, so I went online and downloaded a .step file of the shell. I then proceeded to unstich it so I could remove unwanted holes. After restitching the object, the whole file became extremely slow. Even selecting a face took 30 seconds to compute and I got the error: There was a problem combining geometry together. I tried exporting the file as a .step file and reopenning it in a new file. This removed the lag but I still couldn't cut the body when extruding. The rare times where I managed to cut the body with an extrude function, it would extrude with a slight angle up.
I am very confused and would like to find a solution to these issues
Original file with lag is attached below and named: GB v16
Exported non-laggy file is also attached below and named: Shell v1
Thanks for the time and help
