Profile selection when editing a feature
sricci.design
sricci.design
I noticed that when I go back into an extrude feature to edit it, and I click on the profiles, it only let's me select one profile that that specific extrude command. However, when I start a new extrude command, I can select as many sketch profiles as I want. Is there a way to edit an extrude command and select more than one sketch profile for said command? Have other users experienced this with editing extrude commands or commands?
-S
schneik-adsk
Make sure you activate the profile selection tool in the command dialog.
Hold the control key to add and remove election.
This is true for all commands. Control key is used to edit selections.
Kevin Schneider
sricci.design
Hello schneik,
I clicked on the profile selection box in the command manager and it would show as highlighted. When I went to select more than one profile that is when it would fail to work. It would deselect the first profile I selected when I went to select an additional profile. I tried holding down command (mac) and or shift and it didn't fix the problem. Anything else I can try?
-S
Sent from my iPhone
michallach81
Try to hold ctrl, te preview will disappear and you will be able to select more profiles, same is with any other feautre (fillet, sweep, just any other).
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
