problems with patterning properly
Okay guys and gals I'm stumped.
I just struggled through my first model that I designed to be laser cut and some things still are not clear. I'm now designing another product with similar features and the process I used to make the first model and they are not working in this second one.
So here is the issue:
In the first model (attached ) I designed parts that have tabs and clips that lock into other parts. I also attached an image of what these tabs and clips look like. In this first model I tried different ways to pattern these tabs and clips around the rectangular bodies and found success by first modeling the rectangular body, then sketching the tabs and clips and patterning them around the rectangular body using patterning faces, as I could not get pattern bodies to work like I was encouraged to do.
I m now trying to do the exact same process in my new model and when I try to pattern faces I get an invalid input and nothing shows up after the command, and I am doing everything the exact same.
What I would like is for someone to explain the proper way to add all these tabs and clips to my parts as I am going to be making a lot of products that use the same construction.
I've attached an image also of the back piece that Im trying to add all these tabs to with arrows where i would like them
I'm someone could show me how they would to this properly I would greatly appreciated .
Regards, Pearson
