Problems with model size respect to "file size"
Hi everyone, When I open this imported STEP file, it appears so small as shown in the first pic. I tried to set FRONT and HOME views as shown in the second pic, but when I orbit or pan, the model get lost in the space. As you see, the model origin is well placed. What should I do? Thank you for helping me!
I attached the STEP File
TheCADWhisperer
Reset Home Position.
Reset Home Position.pngAnomaly.PNG...but I think there is actually an anomaly in the imported geometry - might be worth running a Quality Check.
Found several issues with the quality of this geometry in Autodesk Inventor Professional.
Not sure how to check or Repair geometry in Fusion.
Thanks for reply. I tried what you suggest but it still remains the same, however I realized the error that you're indicating. It seems that the file is broken, because I can't cut or extrude faces. I'll search for another STEP. Again, thank you a lot
