Problems to identify constraints
I just like to ask do some other users find some difficulties to identify constraints, which constraint belongs to which point or line? I have found it quite tricky if you have several start/end points in same intersection. Could it be possible to get also the line highlighted to which the constraint belongs to, not only the end point when you pick the constraint symbol? I have also found sometimes quite difficult or even impossible to remove all constraints from a certain line.
The other question is, how you prioritize the development of the program? Though the program works quite well nowadays, I think you also admit that there is still some lack of functionality in basic, everyday workroutines. Most of cases they don't stop your project but they could get the user quite frustrated. If I have understood right, the IdeaStation's voting mechanism is in quite important role when you decide the prority of a demands. I believe, that you have several "hardcore" cad users in your development team; my suggestion is,that they should have at least 80% authority to decide the order of development. The rest 20% should be given to community members. I understand well, that the community gives brilliant ideas, but same time the focus could be spreaded.
Thank's!
