Problems Study Modal Frequency
miano_s
miano_s
HI,
In the attached study type Modal Fequency (vibrazioni),
I constrained the bodies but I have 6 Rigid Body Mode.
what am I doing wrong ?
miano_s
he problem is the point mass If you delete it, it works
miano_s
I understand, the mass point is constrained
Is it a bag?
Mike.Grau
Hi @miano_s,
Thank you for your post in the Forum.
Please, let us work through the case which we have created.
I will have a look at your design and check a couple settings.
Thank you,
miano_s
Hi @Mike.Grau,
Thank you,
I send two very simple models.
The first is correct
The second has in addition a manual point mass.
The second model fails because it does not take into account constraints.
miano_s
Hi @
Mike.Grau,
Thank you,
Mike.Grau
Hi @miano_s,
Thanks for the update.
Yes, I have been able to reproduce the issue.
The model is loosing the constraints as soon as you apply a point mass.
That´s not what you expect, running a frequency analysis.
I will go ahead and log this with the development.
Thank you for raising our attention to that
