Problems doing fillet and trim
I'm having problems with getting my sketches done.
This is my first more complex project on Fusion 360, so there's been quite a lot of back-and-forth editing on every element and the file seems to be a bit messed up, but contains so much work I cannot start anew.
Here's the latest problem: I'm modelling a 3D print and want some corners be smooth to make it easier to slide prints over each over, but I cannot get some corners rounded.
First I tried the Fillet function, but just gives error "Fillet cannot be created", and no details to tell why.
Next I tried to do it manually by drawing a circle and trimming the sharp corner, but it doesn't work either. I tried using "Trim" and "Break", but neither works. Trim shows the section correctly:
But regardless of how many times I select the section it does not disappear. I then used break, and against, it shows the red cross and I click, but when I select the line it's all there and gets deleted as whole.
So I'm stuck with invincible line segment.
What should I do?
