problem with spiral cone not being flush
meisterpumpernickel
meisterpumpernickel
Hi everybody i created a design with a cone spiraling. my proble is that the end is not flush (see screenshot) does anybody have an idea how to solve this?
mango.freund
are you sure that your axis is perpendicular to the part? did you use a small angular offset?
meisterpumpernickel
hi thanks for looking into it. i am not sure i understand your question. Do you mean the axis of the viewpoint, where i did the screenshot? The view is from an slight ofset angle.
mango.freund
Correction, after thickening the wall thickness * 2 indicates the offset. the outside edges are the same length. the inside edges are shortened by the incline
mango.freund
mango.freund
meisterpumpernickel
thank you. is there any way to avoid this or correct this?
