Problem with Rendering
mloots8
mloots8
So I'm fairly new to Fusion 360, finding my way around the basics came easily though and I've been through some of the basics in the model, render and simulate environments
I'm having a problem however with rendering. I've designed a hydroponic bed, as well as the containers for the potted plants that go into the bed and then added these together as components in another design. 10m long by 1.2m wide by 1m high with 215 holes for plants. This renders just fine.
Then I made another design and added 3x5 of these beds to show how they would be layed out in the project I'm working on for varsity. This means about 50m by 6.6mm.
However when I tried to render this I got a message saying "The design is being saved and synced to the cloud. Rendering will be enabled when done." So I gave it a while, but I have never gotten it to render, after trying offline mode, being connected and disconnected from the internet, restarting the program etc.
I still get the same message, and I thought it might be due to the huge size, but I have now gotten the same for a small (220x180x100mm) design within the same project that I did after this one.
[This is before I can choose between local/cloud rendering so I don't believe it has anything to do with cloud rendering.]
Sorry for the long explanation, was just wondering if somebody knew what I could do to solve this problem
Thanks!
-Michael
TrippyLighting
Have you tried to render it in the canvas ?
chengyun.yang
Can you please check the data panel to see if your design has been uploaded to the server(Probably try on another machine to see if you can download it without problem)? From the message itself, it indicates the design is still in uploading status.
mloots8
I've tried it now and can render in the canvas, albeit slowly since my laptop doesn't have a dedicated GPU. I'll be on a PC later today with one so it should go faster, but I still get the same message when trying to create a render.
mloots8
When I go back online with the program I can't find this design in the data panel. However when I try switching back to offline mode it says 'some file uploads are still in progress'. I guess this design is just taking a really long time to upload due to its size.
I'll give it another hour and check back on it later and get back to you.
Thank you
