Problem with mesh convert
Hello guys,
i'm trying to convert an obj or stl mesh into a solid body. The mesh is from a Shinkansen quite complex with a lot of triangles. I used different techniques to convert this model: Direct convert to a Face and final thicken. This was also done after creating a quad obj mesh in 3ds max to use T-Splines. But only the "no faces supplied" dialog pops up. Also after dividing the model into smaller and easier sections. An other Method was to create a solid in Netfabb, but this alo failed "mesh to brep error".Last method was to send it to FreeCAD and create a solid Body via tool. None of this methods worked and I am stuck right now. I hope anyone can solve this issue because this would help me a lot. I also attached all files in this post.
Thanks for your attention and help.
